Help figuring out what I bought
  • Help figuring out what I bought
    I just bought an argo 8x8, i believe it is about a 1981. It came with a kholer 398cc 2 cylinder 2 stroke.
    There are no markings on the body or frame that I can tell, which would give me the model and year.
    Here's what it looks like
    I need a parts manual for it and an idea where to buy things like a gas tank, axles, etc.
    Any help would be much appreciated.
    Can you locate any number off the transmission ?
        I believe 78/79 was the last year for the 2 stroke models,I can't remember a lot of my info is on my broke down computer.I have a gas tank and bracket that i have been trying to give away out of an 89 Argo if it would work.
          @coosaridgerider - That would be awesome if it fits! Here is what i think it should look like
          The machine had no engine in it, but the guy I bought it from gave me a kholer and a chapparal. The kholer is smaller so I assumed that's the one that came in it. I think he said the machine is a 1981, but i have no way to confirm that yet.
          If we can verify the tank you have will fit, I would be extremely greatful to you!
          @Argo Guy - I have not looked on the transmission but i will clean it and do so. As of now i think this is it
          I'll post the serial or model number if I find one on it.
            The gas tank looks the same as the one in the picture. It needs a good cleaning and the little piece where the gas line fits is broke but that is an easy fix. I will have to find the brackets,hope I didn't throw it away.
              I do have two brackets, well more like straps that bolt to the seat mounts, they are number 17 in the image above.
              Here's what I have for the tank assembly
              Where are you located? I am in Michigan and will obviously pay for whatever shipping is.
                There's a number stamped on top of the transmission "1537", does that help?
                  It helps a lot you can either contact ODG or your local argo dealer they can run the number and tell you exactually what you have. I had to do that with mine and found out it was newer then I thought. They were also abel to give me a serial #
                    Thanks, what is ODG and where do I contact them?
                      Call gene's Argo he can help you with the serial number and any parts you may need.319-658-3801. Send me a pm with your mailing info.
                        Great thanks again, and I'll pm you asap.
                          I called a couple argo dealers and was told they cannot figure out what year it is simply by the 1537 stamped on the transmission :-(
                          They say there is supposed to be a serial on a metal plate on the dash, but of course there's nothing on this entire machine. Anyone want to take a video tour of it and make some guesses?
                            Video
                            Here's the video tour for you What year is this argo?
                              Tinodesis has one very close to yours in his photo gallery. Argo made the first 8x8 in 71 and ran 2 stroke till the late 70s. The one you have would have to be between 71&78/79. Without the serial number it would be hard to figure out the exact year.
