leak testing an attex
  • #31
    Originally posted by Bikerman883 View Post
    So take the metal out of the inside also. What do I do with the parts that are offset and I can't get back even? What's the best to do with the hole?
    You can use a heat gun to reshape and bend abs. Just make sure you keep it moving around on the material. I used a piece of abs to fill my muffler hole up and good it flush.
    • #32
      Has anyone every tried find a close yellow paint to match it? I have had do some bigger repairs and was thinkng about cleanign grease and dirt off but painting to match the body evenly. not sure if a dumb thing to do since it took me about 5 days to get the rhino liner off the entire tub
      • #33
        ...since it took me about 5 days to get the rhino liner off the entire tub
        Lol. Now you can see why we hate paint.
        Is the abs goo off color?
        • #34
          I used a Hot Stapler from Eastwood on two 12" cracks at the rear axles on my 400 chief. Then used goo and fiber. Solid as a rock.
          • #35
            ok repairs all done, and put about 4in of water inside and no leaks, yeahhhhhh. it doesnt look the prettiest but i put it on thick so it holds better.
            • #36
              can you post a picture of the repairs
              • #37
                Before and after
                Here is one of the after pics
