my first 6x6 / attex build
  • #16
    Is there an air filter that will go right on the back of the carb instead of that air box ?
    • #17
      Yes. Just get a universal fit Uni-Filter. They sell them at any motorsports store for about $20. Just give them the dimensions of your carburetor and you'll be all set.
      • #18
        Well I have got it up running and it is a blast to drive but my 3rd ride it popped out of gear and rolled In to a tree backwards so bummed out
        • #19
          Glad to see it up and running! They will hit trees occasionally!
          • #20
            Oh, will "THEY" ?
            • #21
              Well I hope not. I think I will make a body band now that might stop it from cracking the body if I bump in to something next time
              • #22
                THEY , the ATV's driven by ME and my kids hit trees occasionally. Once you install the body band, hit the trees with the body.
                When you hit them with the tires, the axles bend
                • #23
                  Nice work
                  ST400R ATTEX(Smiley)
                  500 Super Chief
                  • #24
                    Thanks
                    • #25
                      Will h5006 headlight work in my 6x6?
                      • #26
                        They work but they use almost double the power that the 18w stock lamps used, so you may find that the charging system won't keep up with them if you use the lights a lot.
                        • #27
                          OK both of my lights are burned out I didn't know they were 18w the lights I found are 35w . do they make that light any more or would led lights be best
                          • #28
                            LED would be great, but I've never seen any this size for a reasonable price. I use 35w work lights from Tractor Supply, but they still use more power than most of the two-stroke charge coils will keep up with. If you happen to find some LED lights that will fit and they don't cost an arm and a leg, make sure you post your source. There will be people interested!
                            • #29
                              I found these led oneshttp://www.ebay.com/itm/2x-New-5-Inch-Round-Pair-Sealed-Beam-Conversion-LED-Headlights-US-SELLER/121251251206?_trksid=p2052191.m2338 for 79. but I am going to try this hid set for $60 5 3 4 inch Round Clear Round Crystal Headlights Light H4 6000K HID Kit | eBay
                              • #30
                                Dose it charge fine with the 35 watt lights ?
