I went to attempt to remove my steering levers on my green poly body Attex project and they were REALLY stuck! I tried penetrating oil and a big pipe wrench without any luck. I was told that people who had that problem with their machines had to take a torch to them. I got some heat on the tubular housing where the steering levers go into with my oxy acetylene torch. I got it red hot and had a friend of mine turn the sticks with the pipe wrench. It moved a little bit, and then I repeated the process and it came out!
The second one didn't work out so well, since the steering stick broke off in the tubular housing. I got the torch on the broken piece in the housing, got it real hot and just melted the remainder of the broken stick to melt down to the bottom of the housing and it was then out of the way.
If you are having the same problem with getting the sticks out, try spraying the penetrating oil down the tubular housing where the steering sticks go and try to turn it one way and then the other with a pipe wrench. This might not work, especially if your rig was sitting outside for a long time and nobody ever used any anti-seize compound on the sticks. I would highly recomend heating the tubular housing for the sticks and then turning them with a pipe wrench. When you turn the sticks with a pipe wrench make sure you turn them a couple turns clockwise and then counter-clockwise so that the sticks don't snap off.
The second one didn't work out so well, since the steering stick broke off in the tubular housing. I got the torch on the broken piece in the housing, got it real hot and just melted the remainder of the broken stick to melt down to the bottom of the housing and it was then out of the way. If you are having the same problem with getting the sticks out, try spraying the penetrating oil down the tubular housing where the steering sticks go and try to turn it one way and then the other with a pipe wrench. This might not work, especially if your rig was sitting outside for a long time and nobody ever used any anti-seize compound on the sticks. I would highly recomend heating the tubular housing for the sticks and then turning them with a pipe wrench. When you turn the sticks with a pipe wrench make sure you turn them a couple turns clockwise and then counter-clockwise so that the sticks don't snap off.
I would suggest your neighbors lawn
