Would a pair of U joints work as well, instead of CV joints. I hear from mud bogging crowd that they are a bit mor suited to the exposure to elements then CV which can give up after water or dirt get into the boot
Attex Springer
They used u joints in old school springer. I believe the degree of the angle is beyond there suggested rating. cv's can take it better.Originally posted by jwiereng View PostWould a pair of U joints work as well, instead of CV joints. I hear from mud bogging crowd that they are a bit mor suited to the exposure to elements then CV which can give up after water or dirt get into the boot
angles
What degree angles would a whipper style springer be subjected to? I am not a trigonometric specialist, or really not a specialist in any type of math, but from whippers posts the suspension adds 9 inches to his width, and ther is 6 inches of travel in total. This means that there is 3 inches of travel from mid to either extreme. Using the tangent ratio, such that tanX = opposite/adjacent where X is the angle in degrees, and opposite is 9 and adjacent is 3. Therefore the angle is roughly 18.4 degrees.
I would agree that this angle is a lot to ask from a U joint. Considering the speed of 60 MPH the tire rotation must about 850 RPM.
I see some U joints from Princess Auto rated for 15 degree continuous at 1000 rpm. They are 30$ each
check my math, I might be off, not my forte
too much time....Originally posted by jwiereng View PostWhat degree angles would a whipper style springer be subjected to? I am not a trigonometric specialist, or really not a specialist in any type of math, but from whippers posts the suspension adds 9 inches to his width, and ther is 6 inches of travel in total. This means that there is 3 inches of travel from mid to either extreme. Using the tangent ratio, such that tanX = opposite/adjacent where X is the angle in degrees, and opposite is 9 and adjacent is 3. Therefore the angle is roughly 18.4 degrees.
Why change what is working?
Springers!
Wayyyyyyyyy over my head on this one....
i'ld prefer to leave it to the scientists..lol
I agree with you LarryW, why change what is working. I was not suggesting that whipper should change his, but I was considering alternative methods to the same end, for people who want to build a similar rig, but can't get a hold of CV joints
Oh, I see. Best bet is to find some cheap ones from an automotive and use them. Have to look around and research what is best price and easy to use.Originally posted by jwiereng View PostI agree with you LarryW, why change what is working. I was not suggesting that whipper should change his, but I was considering alternative methods to the same end, for people who want to build a similar rig, but can't get a hold of CV joints
SWEETTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT great vid whipper love it and lewis you are the man thanks pal. alley sez WE are comeing to az . robbie alley hunter
R.I.P sage rogers 4 11 09 .
great videos Whipper! Great pictures to
