Hi everyone, I am new to 6x6world. As my user name may suggest, my creativity in names is somewhat lacking.
Anyway, I got an Attex Wild Wolf 295 from a friend that needs lots of plastic attention. I have already made a friend at a local plastic company and acquired raw ABS pellet, and made the acetone/ABS goo. There is a MASSIVE crack running the length of the left lower body's underside, front corner to back (Not fixed), and misc. other cracks, which I have already repaired. I am noticing that I am getting bubbles in the cured ABS. I am applying it VERY thin, (Dave on route 6X6 sais 1/8" thick max), but I am keeping it thinner, and tried brushing acetone periodically, as he suggested, to allow gasses to escape, but no dice. I have backed up all the repairs with a surface coat about 3/4" around all the cracks, but I can't do this on the bottom crack's outside, and this is the one that counts. I maybe have 1-2 minutes float time if it opens up, WITH the bilge pump I am installing running full bore (I new I kept that old boat around for something) Any ideas as to how I am screwing up? How thick should the goo be? Please help before I scratch clear through my skull!
