Have any of you attex 6x6ers used a keyed 1inch shaft with a taper bushing and sprocket set up?? To eliminate using the tube on sprocket and through bolt.
If so could you share how this worked out. Seen a machine other day with this setup but it had barely been run and not run hard so I'm kinda curious how this would hold up to abuse!!
Thanks
Dave Phelps
Thanks
Dave Phelps
