OK so Im new to the 6x6 thing so go easy on me. I recently purchased a 1974 Attex with 295 engine. After a short time i realized i had no spark. I am getting voltage to the external coil but only 3 volts instead of 6 like it is supposed to. My question is this enough voltage that i should be getting spark or do I simply need a new ignition coil. For clarification I am refering to the coil inside the flywheel as ignition and the external one has the plug wire on it.Thanks for any help. Im really excited to hear this thing run.
Attex 295 Wild Wolf no spark
Have you had the flywheel off and checked the points yet? If you haven't check there first. Try cleaning the points with some fine sandpaper. Any time that I have had one I have had to replace them. The points are where I would start."Racing is life. Anything that happens before or after is just waiting."
Well I have spark now but it still wont start. Even with starting fluid. Any ideas of where i should head next? Carb seems to be clean. Exhaust not plugged. It does not appear to suck air in the carb with my hand over the opening. How do I tell if it is crank seals or just need a top end rebuild? I plan to rebuild it at some point in the near future anyway but would still rather hear it run before I do if its a simple fix. I dont have a compression guage but it does blow air out of plug hole when I stick my finger in it. I was told that this 6x6 set for several years because one day it just wouldnt start. Thanks for the help!
Does it pull real easy on the pull rope or is it a thump thump as you pull the rope? New spark plug?Originally posted by 507rzr View PostWell I have spark now but it still wont start. Even with starting fluid. Any ideas of where i should head next? Carb seems to be clean. Exhaust not plugged. It does not appear to suck air in the carb with my hand over the opening. How do I tell if it is crank seals or just need a top end rebuild? I plan to rebuild it at some point in the near future anyway but would still rather hear it run before I do if its a simple fix. I dont have a compression guage but it does blow air out of plug hole when I stick my finger in it. I was told that this 6x6 set for several years because one day it just wouldnt start. Thanks for the help!
With pull rope you should have quite a bit of resistance when pulling,try turning the clutch and see if you hear like a hissing sound maybe from carb side or just to check resistance that way. My 295s pull quite stiff.Originally posted by 507rzr View PostWhat if I don't know exactly where it was set ? It don't even try to run. Seems like it would back fire or something. I'm thinking compression.
http://www.6x6world.com/images/jlo-t...-manual-09.jpg Try this linkLast edited by dave phelps; 08-23-2017, 09:36 PM.
Try YouTube for a timing procedure or maybe look in the manuals section on here for attex and it may be in there also.Originally posted by 507rzr View PostWell I have replaced the points and have very good spark. Also rebuilt top end. Now I need a procedure to set the timing. Still won't start but get an occasional pop on starting fluid. Gonna tack apart carb and clean it. Any other advice?
Good luck and keep us posted
Thanks
Rebuilt top end and replaced points. Have tried setting the timing in multiple different positions. Had the carb off and cleaned twice. Wont run on ether either. Still cant get it to run. Any suggestions on what to do next? Getting pretty aggravating.
A simple yet possibly overlooked issue. Is the starter turning in the correct direction?sigpic
