Originally posted by 507rzr
View Post
Attex 295 Wild Wolf no spark
Do you have any way to prime the carb? You may not have a problem, you might just have no fuel in the carb. I would try putting gas in spark plug hole a couple more times. When it tries to run the pump should pull enough gas to get it started. If you don't have a primer for the fuel pump I would put one in or you will have the same problem over and over again."Racing is life. Anything that happens before or after is just waiting."
I had a few extra minutes over the weekend. Kept trying the fuel in the plug hole thing. Its very close to running but it dies when i let off the key from the start position. I had to replace the key switch when i first got it. May have wired it wrong or im just not getting fuel in engine yet. I did partially shear a flywheel key in the process, that leads me to believe that my timing is off. Hopefully i am finally on the right track.
Float level could be wrong and not letting fuel in thru the needle and seat? Jets plugged? Will start if you put gas in cylinder?Originally posted by 507rzr View PostWell still no luck. It almost runs during crank but not quite. Getting fuel to carb but not sure it's getting in the engine. Any suggestions?
