First 6x6 500 Super Chief
  • #16
    Where do you want to put the bedliner?
    • #17
      I was thinking the whole veh???
      • #18
        Short video of her first test, just got the new carb.
        https://youtu.be/T8Jg-lc3NNA
        • #19
          Originally posted by NIGHTOW1 View Post
          Ok I know I have read not to use bed liner on these vehicles, mostly because it won't adhere. I have a friend who had his Gator done with LINE X, and he loves it, the local company says it will stick with no issues and if is dosent no charge. If it works this stuff is basically indestructible. So let's hear it?????
          Bedliners*|*LineX
          Ok I'm interested whether iy will stick to that poly myself! If your guy says he'll give you a full refund if it peels off I'd go for it if that's what your wanting. If no full refund I would not because I think it will peel as poly is kinda an oily plastic.
          keep us posted on this.
          Thanks
          • #20
            If he is willing to put it in writing, i might do it.
            • #21
              That's the only way I'd do it!! if it starts peeling then what???? sorry but your on your own and now you have a full blown mess!! LOL
              • #22
                If i deceide not to, how and what do you use to paint tjese, minw is pretty bad. I would love to fimd a better body, but im afraid it would cost way to much?
                • #23
                  I have no clue, can you get the rest of that paint off??
                  • #24
                    Its not the paint thats the problem, the PPE is getting old, and looks , i dont know pitted.
                    • #25
                      I have one that looks a tad bit like that. I've never tried to do anything with it. It sat out in the sun for 15 years and still looks pretty good considering that! Thought it would've been junk but that's the top half of my trail machine now.
                      Anyone else have any ideas besides heating the body up?? Scrubbing maybe? Looks like high pressure washer lines in it now??
                      • #26
                        That's what I thought it looked like. I was going to try so!e heat see if that worked any idea what temp?
                        • #27
                          I used a heat gun on a max and it had to be pretty darn hot. It looks like it gets shiny or oily and that's the time to move the heat to different spot. Start in a spot that's hidden you'll be able to tell
                          • #28
                            My gun will go to 500° rhink that will work?
                            • #29
                              Should I think. Not sure what mine got too. Cheap harbor freight model and I heated my body enuff to mold above the tires
                              • #30
                                Wjat do you mean mold? I have a few spots I need ro fill where ir lools like tire rub!
