Shifter
  • Shifter
    Does anyone have a good picture of the original shifter from a first gen Attex with a baker hill transmission? Thanks.
    If you look at andyinva pics and duck89 pics you will see just a piece of flat stock, i think it had a one inch downward bend outside of floorpan. Had to be disconnected each time floor came out.
    Don doesnt have one in Attexland?
      I went through all of the pics in the gallery and I may be wrong but the ones that show the shifter don't look original and I can't find any that show the entire thing. What is Attexland?
        I'm not sure if I have a picture or not, but it's a highly sophisticated piece of engineering: 1/2" band stock with a hole drilled in one end and a loop on the other . It slides through the hole in the floor pan and is held in place by the pin at the trans shifter. I may have an original here, but I'd have to find it (not an easy task). They're easy to make.
          That is what I'm thinking, put the machine in reverse and give an inch after floorboard to get behind it and make the bend.
            I figured I would fab one but I want to make one like the original, that is why I am looking for a pic. The one I have is just a long piece of threaded rod. Doesn't work worth nothing.
              Maybe Andy, Adam, Marty or LarryW will lift the seat and take a picture and some half near measurements, they may have came 2 ways depending on the vintage.
              I don't think the one for Jon's machine went to Rick when I sent it, or if it did I did not tell him what it was, pulling it to remove floor is a pain but so is lifting the seat. ( pun intended )
                Andyman hooked me up with some pics! Just what I needed!
                  Post it up for all who need one to see.
                    I would like to see that. Need to make one for Jon's 300. Been lazy and focused on 295. Thanks
                      Here they are!
                        Thanks!!
