I need help with my baker hill. so i adjusted my linkages to where the sticks dont hit the body anymore. but i can barely pull the sticks all the way back cause they almost hit me. i need help with this. Thanks
1st gen Attex with Baker hill
Have you adjusted the transmission pucks? There are adjustment studs on the back of the calipers. Loosen the 9/16 lock nut and turn the stud in with a 3/16 Allen wrench to the point where the play is out but the disc still turns when the stick is in the neutral (centered) position. If the pucks are in good enough shape, you'll be able to adjust the excessive movement out of the sticks.Stuck in the seventies- not in the swamp.
No, you should be able to adjust everything in place. If you have to replace the pucks, the transmission shaft will have to be removed.Stuck in the seventies- not in the swamp.
That's a shame. The best results I've had were with the pucks that Richard Clark sells. I'll get you dimensions when I get home tonight, but you want a very hard brake material to make your own.Stuck in the seventies- not in the swamp.
