Picking up my super chief next weekend
  • #16
    What size is it? I believe the stock carb for the G50B is a Mikuni VM32 meaning 32mm. You could also use a 34mm.
    • #17
      Originally posted by 6X6 View Post
      Drew, called on that machine a few weeks ago, but it had sold. Two S.C. machines at 1000 won't last long, even if one is for parts, hopefully a site member grabbed those.
      These are the 2 machines I bought for $900.00. The supercheif is in good condition, the other is a 400 cheif
      scot
      • #18
        Good buy. A descent S.C. alone is well worth it. I bought one this past fall for 900. But a parts machine just sweetens the deal. I was under the impression the second was a S.C., and called to confirm, only to find out it has sold. Glad you got em, you'll love those guys. While Max and Argo machines are great and mostly unstoppable, the little Attex holds it's own, and is quick as hell doing it too
        Attex Super Chief - Sold.
        • #19
          Another question the top of this super chief is painted brown over attex yellow the botton looks to be black and not painted?
          • #20
            It's black, not dark green? I believe it was available in yellow with the dark green bottom, I've seen machines with the bottom painted black, but I don't believe they ever molded black plastic tubs.
            • #21
              it maybe dark green my florescent lighting in my garage is not the best when cold it is for sure not painted When they painted the top they only painted places it showed the bottom is dark in all places and I see no yellow poking through
              • #22
                the seat is cover in tan instead of black maybe re done ?
                • #23
                  How well will a chief run with tracks? Well it would run fast. I personally wouldn't make the effort though. It would be kind of like putting a snowplow on a Lamborghini. Yea . . . it would work but wouldn't the Lamborghini be a whole lot more fun without it. Not to offend but isn't that what four stroke maxx'es are for. Once you do a few full throttle power slides I am sure the thoughts of tracks and winches and windshields etc, will be put on the back burner.
                  Keep the Rubber Side Down
