I got my SC running and driving today but it seems like you can not get enough throttle to get her up to fast speed you run out of handle what can be done?
how do you get more throttle
have u adj ur center pin in the throttle body that moves ?????? u can put the clip in a lower slot holding it higher out of the jet . robbie1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
R.I.P sage rogers 4 11 09 .
The Superchief had a Mikuni 30mm as original equipment, so the distance the throttle lever pulls the cable may well be insufficient. Levers from PWCs work well and you can usually pick them up fairly cheap on ebay. There may be some mods you need to make to the end of the cable or new lever to make it work. Good Luck!
New Tigershark 640 700 770 900 1100 Throttle Lever PWC - eBay (item 120450616469 end time Mar-13-11 09:18:06 PDT)Stuck in the seventies- not in the swamp.
If you're talking about the needle jet, this won't work. The clip on the needle jet controls the air to fuel ratio at about the 1/4 to 3/4 throttle positions. Raising or lowering the needle changes the amount of fuel that passes by the needle at a given air flow (which is determined by how far open the throttle slide is). Raising the needle and letting more fuel past just richens the mixture, it doesn't give you "more throttle".Originally posted by rdr View Posthave u adj ur center pin in the throttle body that moves ?????? u can put the clip in a lower slot holding it higher out of the jet . robbie
~mLast edited by hydromike; 02-21-2011, 02:11 PM.sigpic
thanks mike ben a lot of years sence i'v work on one . new u or don would know the answer . robbie1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
LD,
I ran into a similar issue when installing Mikunis on my last engine. You want to make sure that the throttle cable not stretched too much. There might be an adjustment at the hand lever to take out some of the slack if there is. I read somewhere that the adjustment on the carb should be used only for fine tuning the slide to sync dual carb set ups which makes sense. If you can't get all the slack out then you might need a new cable or get an in-line adjuster installed. I need to do this on my current set up. After all that if you still cannot get full actuation on the throttle slide you'll need to get a lever like Don recommends."Don't worry my Dad's a TV repairman, he has an excellent set of tools..I can fix It"
