Since I seem to have another bent axle on the AMPhibian, one of my new ones, I expect with all the battery weight I'll probably be getting more. Was thinking of ways to space the outer bearing further out from the tub closer to the wheel to help prevent this in the future. I have some ideas but figured someone here probably already did something similar so I thought I'd check before I wasted too much time on a bad concept. Basically I'm thinking of a 3-4 inch or so spacer with an angled support going back to the tub, with either a brace inside or a plate coming up from the current bearing mounting flange area. Or using another bearing further out on the axle with a support
