Axle support to prevent bending
  • Axle support to prevent bending
    Since I seem to have another bent axle on the AMPhibian, one of my new ones, I expect with all the battery weight I'll probably be getting more. Was thinking of ways to space the outer bearing further out from the tub closer to the wheel to help prevent this in the future. I have some ideas but figured someone here probably already did something similar so I thought I'd check before I wasted too much time on a bad concept. Basically I'm thinking of a 3-4 inch or so spacer with an angled support going back to the tub, with either a brace inside or a plate coming up from the current bearing mounting flange area. Or using another bearing further out on the axle with a support
    http://www.amp-phibian.blogspot.com/
    The original attex adaptor hubs have a steel cylinder that is welded to them and butts up against the inside plate of the 3 lug hub. This cylinder adds support and strength to the axle itself. You could make you own cylinders and weld them on the the adaptor plates ensuring the length is correct to press against that inner ring on the hub. I've considered even welding the adaptor on and using angle instead of a cylinder. maybe 4pieces per hub and making sure you can still access the hub bolts.
      Do you have a link to a picture of these adapter hubs?
        I had pondered doing exactly what your talking about on my wild wolf, but went with 1 1/4 axles instead. My plan was to add a 3rd bearing out close to the wheel with a plate tying all 3 together, then braces running up the the tub where it goes from vertical to horizontal. you might also look into just building a set of Max type bearing cages. Hopefully someone can post or link a pic of one removed from the machine so you can see how they are built... a quick gallery search didn't turn up the pic I was thinking of
          I see that Argo's have a bearing cage:
            the cheapest solution is probbably to weld fins from the axel flange (betwene every bolt) and down the axel shafts. i know that guys with maxes that have the hollow tubes do this the most expensive solution is to get the argo axels you can get the new 2012 argo bearings, cages, axels and seals for about 330, just search the site for a link
            ATV = Alaska Terain Vehicle
