are there seals on the outer bearing flanges> between the flange and body, what is the best way to seal -er- up? also looking for left brake asm, mine's entirely gone.
axle rebuild parts..
Originally, there was a rubber seal between the body and the outer bearing flanges. You can make-do with a bead of silicone sealant in its place if it's missing.
Are you looking for the break "caliper" for the left side, including the disc-sprocket assembly? I have a few calipers for you to choose from if that's what you need....sigpic
Some 3M Strip Caulk works great for the seal between the outer flanges and the body. That's what Recreatives uses on all of the Max ATVs. I use it on all my machines and it works great."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
You can run 22x11x8's on it. I'm running 22x11x8 Goodyear Rawhide III on my Superchief. I've even seen a picture of an Attex with 23x10.50x12 tires, but those probably rode really rough and came very close to the fenderwells.Originally posted by coloradomech View Postyep i just need the caliper, ive got pads and rotor/sprocket asm. Sandblasted, re-welded and re-enforced the frame, now just after the bearings, chains, and tires.can i run taller tires on the superchief? or are 21's the largest."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
