I purchased this vintage Attex and am in the process of restoring it but have a few questions:
1. I was told this is an ST/300/D, is that correct?
2. The belt on the transmission now is a Dayco, and the with does not appear to be wide enough, thus the clutch does not function properly. (It can't open all the way). Is that the correct belt? If not, where can I get the correct belt?
3. The axle hubs need the bearings replaced, and the seals. I think I found compatible bearings for relatively cheap online, but where can the seals be purchased? Do the bearings need to be high quality or will cheap ones purchased online work?
4. The pucks on the Power Transmission are worn. I heard that I can use a hole saw to make new ones from a standard car brake pad, does that work? If so, what size hole saw do I need?
I hope you guys can help me out!
