Ok, so I am prepping for a ride and thanks to hydromike, I finally have enough 3-5 adapters to run my rawhide III's on my Tomahawk. The problem I found is I have 2 tires that currently rub the body when I am moving. Luckily only a little wear was caused during my test ride, but I want to get enough room so I don't have to worry about further damage. I am riding it this weekend, so time is important. I currently have wedged 2 1"x3"s stacked up between the tires and the body. I had to push them in while driving forward. Realizing a 1x3 isn't really 1 inch tall I figure I am about 1 3/4" spaced if the body loosens to the point of the wood. Will this be enough or do I need to get some shims and wedge them in as well?
22" Rawhide III on Attex
Drew are they hitting the top of the body or the side of the machine.
The seat support also holds up the body. maybe you can pull the body up from the seat support by bolting a plate thru the seat support. I have seen some Attexs without the seat support to the frame and some with. My poly body had holes above each tire as it did not have a seat support.Acta non verba
I had an SC with the seat support that was rubbing with 22s on it. I built a frame around it with 2x4s to suspend it by the bellyband and left it out in the sun for a couple days. There's probably an easier way to raise the body, but this way worked for me. Good Luck, Drew!Stuck in the seventies- not in the swamp.
