Last week I had to pull my motor out of my machine to change the starter. While I was in there, I did any maintenance that needed to be done. My question here is there a chain lube that's better than any other. I use motor oil now. I have used a spray in the past.
chaine lube
I've used Chain Wax for many years on my MotoCross Bike. Seems ok on my Max II.
http://www.motorcycle-superstore.com/14/71/988/12473/ITEM/Maxima-Chain-Wax.aspx?SiteID=Google_PLA988&WT.mc_ID=10012&esvt= 0-GOUSC&esvadt=9-0-3886819-1&esvaid=30548&kw={keyword}&gclid=CPLF7vP6hrYCFeyP PAodDiAAXA
I like Amsoil Chain Lube , corrosion-x , and castrol chain lube which has been recommended to me by argo dealer.
ditto here.
Originally posted by srfnson View PostI like Amsoil Chain Lube , corrosion-x , and castrol chain lube which has been recommended to me by argo dealer.
Chain lube is what I would recommend, the names with you guys will be different but over here, chain and wire lube works a treat.
Thick oil etc does not get into rollers therefore, is not really fully lubricating the chain. The thin lube will displace water and lubricate at the same time. The thick oil will lubricate between the roller and sprocket, however it does not penetrate into the most important part and it does also pick up dirt easily.
I jack my machines up and use 4 - 6 cans of spray making sure the machine is just over tick over speed. I will then run it for a few minutes up and down road and then re lube the chains
