whats the general procedure for modifying tubs.for small changes can you soften with a heat gun and press . what kind of material etc. are used for other mods,repairs. thanks johnboy va.
modify tub on max 2
6X6World members egoperf and mike should be able to help you out with this since they're both running 25's on their Max II's.Originally posted by john swenson View Postwhats the general procedure for modifying tubs.for small changes can you soften with a heat gun and press . what kind of material etc. are used for other mods,repairs. thanks johnboy va."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
You're referring to thebuggyman's Max II with 26" tires I believe. That's what you have to do to fit tires larger than 25". But for tires 25" and under, many of them can fit on a Max II by simply heating and molding the tub a little: http://www.6x6world.com/forums/max-a...es-max-ii.html
