H.264 video Max IV
I think the color and contrast looks different than before.. did you take a pre existing clip and run it through ulead, or did you start with raw footage again? If it was pre existing and compressed, then you uleaded it and compresses again that would limit quality. I'm on this de interlacing kick. It's doing more for mine than anything else. Deinterlace first and then do your regular Windows Movie Maker thing. I don't have WM Maker or a digital cam so my route is different. If movie maker doesn't have deinterlace option then I'd get Roger to walk you through VirtualDub download and setup. Would have to see what file type VD saves in that WMM likes, etc. Or maybe you could process through WMM as usual and then deinterlace in VD and then > youtube.To Invent, you need a good imagination and a pile of junk. (Thomas Edison)
h.264
It was a previous video that was reprocessed. I'll have to try the raw footage thing and see if it works any better.Originally posted by Roger S View PostI think the color and contrast looks different than before.. did you take a pre existing clip and run it through ulead, or did you start with raw footage again? If it was pre existing and compressed, then you uleaded it and compresses again that would limit quality. I'm on this de interlacing kick. It's doing more for mine than anything else. Deinterlace first and then do your regular Windows Movie Maker thing. I don't have WM Maker or a digital cam so my route is different. If movie maker doesn't have deinterlace option then I'd get Roger to walk you through VirtualDub download and setup. Would have to see what file type VD saves in that WMM likes, etc. Or maybe you could process through WMM as usual and then deinterlace in VD and then > youtube.
original footage
The original footage for this video was recorded on an sd memory card was wiped out when I used the camera again. I will have to try getting some fresh video and starting again.Originally posted by mudbug3 View PostDan,
From what I have read , each time you re-edit a video , the visual quality gets progressively worse . I,m sure this is why this video was not as good as the original oneLast edited by mightymaxIV; 05-04-2008, 03:20 AM.
