Hi All,
Having just got a Max II, I have split the top cover off the lower tub to give it a service and check over but it is pretty filthy in there with mud, old grease etc.
What is the best way to clean all of this out without causing too much damage to things such as chains/bearings etc.?
I was thinking of tipping it onto its side, slightly more than 90 deg. so the water and gunk can freely run out and then just pressure washing everything as best I can, followed by a good going over with an airline and then just re-greasing all the bearings/sprockets/chains etc with fresh grease and chain lube.
Is this generally how its done, or do you have some better suggestions and tips?
Cheers, Ian
Cheers, Ian
