It's video time
I LOVE the Rotax sound 'Tech! Did you ever change the drive clutch on that engine? I know this was the test run, but I forget if you ever changed the engagement point. You're using an aweful lot of RPMs, that should be translating into gobs of eye-watering speed. The 503 makes a lot of torque (for a two stroke
) in the lower RPM range, and you might benefit by swapping over to a clutch that is more adjustable than the original Bombardier equipment.
~msigpic
No, that's something I've procrastinated on doing (partially due to the cost and partially due to the fact that I can barely get my belt off between the current clutch and body as it is now). The comet clutch looks tad bit larger. I'm open for any suggestions.
Originally posted by hydromike View PostI LOVE the Rotax sound 'Tech! Did you ever change the drive clutch on that engine? I know this was the test run, but I forget if you ever changed the engagement point. You're using an aweful lot of RPMs, that should be translating into gobs of eye-watering speed. The 503 makes a lot of torque (for a two stroke
~m
Row Boat Climb
I climb this before playing around and had no problems. Had some problems today but maybe it was the snow. I had my son filming and didnt relize how long he had it taping and there was a spot where I was going straight for the fence. I was actually trying to cover up the holes by skidding over them in a turn, lol. I didnt hear him asking to stop either. Just some good fun.
Heath ,
I wonder how many forum members would venture out into a swamp like this alone , with out another amphib following them for back up ?
swamp part 4 - Putfile.com
Before the day's of the argo, I walked those swamp's in neoprene over-all's hunting!
You can't gauge by me, I'm the weirdo!
Jeff
02 Argo Bigfoot
