got all this tubing out of dumpsters,3 hoop piece from tire shop used to inflate tractor trailer tires in case they explode.2 hoops bent from exploding tire but 3rd one strait.other 2 1/4 pipe are heavy duty hammock frames.stock aluminum cage is great,only wieghs 26 pounds and makes a great enclosure frame for cab in winter but dont trust it for going fast!it only bolts to upper body with 3/4 bolts and washers.plan on having a couple center sprocket tubes for different gearing choices all higher! steel frame mount cage and racing harness a must.center hoop will have quick disconect recievers on frame similar to a 2" hitch,front will do the same to the upper winch support.extra rear bar going into stock rear upper bodyhole for a little extra support
Cheap Rollbar
the black duct tape instead of welds is an awesome idea!!! what a time saver!
but really, that is a sweet looking designA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
the dirt bike does make it a little top heavy.....but it looks cool
since both roll bars will have excellent strait ahead lighting,wanted some light low and and on the sides where obstacles could hinder turning,rocks,tree stumps ect. the one piece all rubber light housing is waterproof and seals in headlight hole in body,nothin holding them in right now but perfect fit! although they are more vulnerable the upper body lip still sticks out further in case i bump a tree and there will be a push bar protecting them as well.
