Just a couple of thoughts - As far as turning the bearing around so the lock collar faces the outboard side, make sure this doesn't throw the chain alignment off (center axle to the T20). If it doesn't I would not be concerned about the axle running in only 2/3rds of the bearing race.
If you have to modify the axle, have your welder buddy just drill and tap the end. Use a bolt and washer and you won't need a lock collar on the inner bearing. This would be cheaper than extending the axles.
