Hi all,
well,
in the ongoing process of getting my Hustler in shape....
I ended up taking a link out of two of the chains to get enough adjustment to actually tighten them. they are both the front axle drive chains, l and r.
The p.o. had put new chains on, but, it would seem got them a little long......the tensioners were at thier max.
I also noticed on one that it didnt sit square with to the chain.....The only fix I came up with, and, it worked, was to grind the grooves in the clamping nut deeper at one end, so, it would pull down on the clamp, lowering the outside of the bolt, and, making it square.......
I also noticed that the holes in the sprocket mounting tubes were oblong. They seemed on purpose that way, though, since, there is a cast "ring" in the same shape around it.....the holes in the axles are just fine and round.
And, it seems the bolts don't tighten on the tube, but, the nut hits the shoulder of the smaller diameter thread to shaft area.
does this sound right?
I'm new to this, and, don't find it addressed in the info I've looked through here in the archives.......
Now, to tackle the electrical stuff..........
well,
