Has any one ever made a 'skid plate' of a husler???? I am thinking of glueing a heavy ruber mat cut to fit to the front of my unit. Just to pretect it!
Skid plate!!!
Hey Russh,
I made an effort at putting a skid plate on my Attex. I bought a sheet of HDPE (1/4" thick) and conformed it to the bottom of the machine by using a heat gun and lots and lots of jacks and rivets. It turned out pretty well. Check out the pictures in my gallery....
PM me if you have any questions about it. It was a pretty arduous task, but worth the effort!
~msigpic
nice fab and application. Was the sheet expensive?
isn't that spray on truck bed liner HDPE?
I wonder if it is, if, it could be sprayed on and stay?
That'd be neat, and easy..........I'd think.....Henry:
I don't know where I'm going, but, I'm on my way...........
Rhino liner would that work?
I know it is chemically engineered to stick to painted metal but would it stick to HDPE?Originally posted by ygmir View Postnice fab and application. Was the sheet expensive?
It is textured so it may reduce the water speed even more and reduce the vehicles ability to slide over terrain with a high centerWhy do we waste tax money on bridges and roads when we can all just drive AATVs
skid plate
Thank you! And.... no. Quite cheap, actually.Originally posted by ygmir View Postnice fab and application. Was the sheet expensive?
These sheets come up on ebay frequently, and they often have several sizes available. It's not a difficult fab job; it just takes patience. Lots and lots of holes to drill and rivets to install. They're the steel waterproof rivets from RI, so make sure your forearms are in decent shape. They will be at the end of the project, regardless. I think my skid plate is held on with about 75-80 of them.
~msigpic
I thought you could get the spray liner un-textured.......Originally posted by Robio_8x8 View PostI know it is chemically engineered to stick to painted metal but would it stick to HDPE?
maybe I'm wrong, it happens quite often.......
If it'd stick, it'd be a slick (*pun) deal, I'd think......Henry:
Thanks for the link, too. I'd not have thought of looking there.Originally posted by hydromike View PostThank you! And.... no. Quite cheap, actually.
~m
Did you put anything between the sheets? If a person had some holes (like me) in the bottome, I wonder if caulking or silicone would seal at the same time?........
Maybe I'll get a sheet and suspend my Hustler over a campfire to heat it and flip it to let it settle in......hahaha
play tribal music and indulge in adult beverages.......Henry:
There could be an Un-Textured type
There could be an Un-textured type I am not aware of I was just thinking of the type I used . I think the texture could be sanded smooth too.Originally posted by ygmir View PostI thought you could get the spray liner un-textured.......
Just in a truck you do not want things to slide around too much .Why do we waste tax money on bridges and roads when we can all just drive AATVs
yeah,
I understand the truck and traction thing. I just thought they added the texture at the gun, and, perhaps it could be not added if it was used for a skid plate.
I still wonder, though, if it would stick?Henry:
Skid plates
Man oh man, playing tribal music and drinking adult beverages ----, while your Hustler turns slowly on the Rotisserie ,That is funny!Originally posted by ygmir View Post
