What is the thingy called that mounts to the lower pulley? Is it a clutch or what? It appears to be worn out. When I attempt to apply the brake to one side and turn, It pops loose. It should fit tightly together, but it barely touches on the points. Can I adjust this so it seats deeper and doesn't slide or does this need replacing? If it needs replacing where can I acquire one? Thanks.
Cam
Cam
