The inner bearings used by Hustler vary thru out the years. It's best to take them out and measure them and hope that they measure 52mm O.D. because those are easy to find and cheaper than the 47mm ones that where used on earlier models. Since you have the K341 you will more than likely have the 52mm which I use SA205-16 bearings.
how do i fix my hustler?
Are those bearings also from Buffalo Bearing?Originally posted by duckhunt81 View PostSince you have the K341 you will more than likely have the 52mm which I use SA205-16 bearings.1983 Hustler 945-HK 627cc Vanguard
2010 Chevy Silverado 1500
1974 Honda ATC 70
1986 Honda ATC 250ES Big Red
There is no Z in Diesel!!
Is there any way to drain the T-20 without taking it out of the tub, or does it need to come out? I was planning on changing the fluid and only rebuilding it if gear oil came out. If it has ATF in it I'll leave it alone.1983 Hustler 945-HK 627cc Vanguard
1974 Honda ATC 70
You can either lift the front end of the vehicle to drain as much out as possible. Or use a fluid suction system a cheapo from an auto parts store works. If atf or type F comes out I would drain as much as you can, flush with some new stuff and put the proper amount in and you should be good to go"Don't worry my Dad's a TV repairman, he has an excellent set of tools..I can fix It"
Well I went ahead and pulled the frame out of the tub. Just my luck the trans has had gear oil in for 10+ years, go figure. Where do I get parts for the t-20? Does the company still exist? If they do I'm only about an hour from Jonesboro so I could go there. I almost have everything to put it back together all thats left are the axle bearings some clean up and paint and now the trans.1983 Hustler 945-HK 627cc Vanguard
1974 Honda ATC 70
Give Recreatives a call they own the mfg of the t-20 and have all the parts.
Contact Us - Amphibious Six-Wheel Drive All-Terrain Vehicles: MaxATVs - Call 1-800-255-2511"Don't worry my Dad's a TV repairman, he has an excellent set of tools..I can fix It"
What's the best way to fix cracks in my tub. It's broke above one of the headlights from the bumper brackets, and there are some cracks and broke spots on the top. Silicone is not exactly a good substitute for solid abs. I've herd of plastic welding kits but they're kind of expensive. Is there a better way to fix it or should I just get a new tub and top...1983 Hustler 945-HK 627cc Vanguard
1974 Honda ATC 70
Ok I fixed the tub crack with quicksteel(should of thought about that earlier lol). Can yall post some pics of homemade exhaust systems for the k341 engine setup? The old muffler is rusted away and i need somthing to get the exhaust out of the tub. I also need a throttle lever, the only one I can find is from a Max dealer and its $35. Is this the cheapest I can get one? The only other thing is a new gas cap (twist on not threaded), and the only one of these I found is from Richard's Relics.1983 Hustler 945-HK 627cc Vanguard
1974 Honda ATC 70
If at all possible, I'd like to get the origional type of gas gap with the guage in it, I could probably find five or six gas caps that would fit it layin around our shop.....same with the throttle lever, I really want to keep it origional. Exhaust pics anyone?1983 Hustler 945-HK 627cc Vanguard
1974 Honda ATC 70
Ok I took some pictures to show yall how it coming along...it should run this weekend, Ive been havin some trouble with the starter for a few days and just now realized that with the rubber gromets on the engine mount, its not grounded (how did I miss this??????). I was wondering about Richard's relics...i seem to remember someone told me not to buy anything from him but he has some parts that I need and cant find anywhere else, plus he claims to have bought out the entire hustler corp stock...is this true? I need some hustler-specific parts that he has...what should I do? (NOTE: the first 3 pictures are from when I first brought the hustler home...the rest I took a couple days ago)1983 Hustler 945-HK 627cc Vanguard
1974 Honda ATC 70
(other 4 pics...) I used sprocket idlers instead of the stock plastic things there are some pics of the special brackets i made for the front ones out of 2 inch angle iron and some 1/2 inch nutsLast edited by Stonewall; 10-19-2009, 11:52 PM.1983 Hustler 945-HK 627cc Vanguard
1974 Honda ATC 70
Wow, y'all weren't kiddin' when you said t-20 parts are expensive!! I just ordered bands, 1 drum, bearings and seals and it was over $800!!!! Thats more than I've spent on the entire project!! Now all I need are a few things from Richard and I'll be done.1983 Hustler 945-HK 627cc Vanguard
1974 Honda ATC 70
