I removed three of the six axles on my 950 with no problems. However the middle right side axle is frozen solid in the inner bearing. I removed the other side middle axle and ran a steel rod through the opening and tried to hammer it out. It will not budge. I have beaten up the inner bearing so it will need to be replaced. I am letting it soak in PB Blaster over night. Anyone else conquered this problem with an inner bearing sleeve frozen to the axle. I may go buy a propane torch and heat the crap out of it. Would it be possible to cut the bearing off? There is not much room since it is inside the center channel. Let me know your suggestions.
Al
Al
