The worst part is now over.
Two pieces of advice going forward, be careful when painting your axles because paint may be thick enough to prevent the new bearings from going back on. Perhaps just paint them from the hub to where the outer bearing rides. Secondly, when reassembling everything use liberal amounts of anti-sieze on the axles, in the sprocket tubes, etc. It will make disassembly a piece of cake if you ever have to remove an axle again. If you don't you will be kicking yourself down the road.
