Originally posted by Dan67
View Post
Dan67's Hustler 950 Rebuild
Sorry to hear about the camera Dan
New Christmas present
Machine is going to look great with the new tires!
Upgrade 2014
Started upgrading to new splined axles from whipper. For now I am doing the center axles that drive the machine. I broke way too many shoulder bolts at busco and it was a down right buzz kill. At the same time I am upgrading to new Argo HDI bearings and flanges on the outer bearings. Whipper was kind enough to machine a drill guide that is just perfect. Got bearings from Buffalo Bearings and HDI parts from Tim at Adair. Local Fastenal now carries zinc coated grade 8 bolts, washers, & nuts. Been busy morning sofar, center axles removed without much problems. Now onto pulling the motor so I can get the broken left rear out and swapped with an older center axle.
Great idea you have there Dan, going with the HDI Bearings!! It really looks stout!! You will be absolutely amazed at how more aggressive you can drive now, knowing that you will not shear any more pins,,,, well at least not on the centers for now!!!!! Looks good Dan, courtesy of Whipper!!!Originally posted by Dan67 View PostStarted upgrading to new splined axles from whipper. For now I am doing the center axles that drive the machine. I broke way too many shoulder bolts at busco and it was a down right buzz kill. At the same time I am upgrading to new Argo HDI bearings and flanges on the outer bearings. Whipper was kind enough to machine a drill guide that is just perfect. Got bearings from Buffalo Bearings and HDI parts from Tim at Adair. Local Fastenal now carries zinc coated grade 8 bolts, washers, & nuts. Been busy morning sofar, center axles removed without much problems. Now onto pulling the motor so I can get the broken left rear out and swapped with an older center axle.
BIGFOOT ALUMNI
