sometimes its to easy of a fix seems to be running good SPARKPLUGS new ones lol will give more details saturday we are taking it to the woods for some test runs before i take it to the UP for bear season again thanks to all for the help tim
added to collection
fighting the same thing with a boat engine. keeps losing spark in one hole. Don't just order parts without trying to figure out the problem first... gets expensive that way.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
yeah we tested the coils one was ok not real good other was very poor not getting hot spark all the time we already replaced condensors points took carb apart cleaned it new fuel lines battery all new wiring and different fuel tank tested lower end on engine for leaks none found and new spark plugs and did commpression checks on both cylenders and both were good we will see lol thanks for suggestions all have been used glad i still have my modified golf cart lol
any one replaced reed valves and where did you buy the replacements from thanks we are getting closer to making this thing run lerned these are what makes the vacumn in the engine and also keeps fuel from backing in and out of carb in simple terms a check valve system
you may try denniskirk.com they use to carry parts for old sled motors another shot may be boysen reeds if you could provide dimensions number of petals something may match up i agree with flipping them over in some cases usually they are bowed so bad they wont seal tight if you could post a picture would help also to see how good or bad they are
well we put in the new gaskets and it started up perfect idled and accelerated turn it off and now wont start again seems to be blowing gas out the carb help this unit goes north wed running or not but i might have the 1st amish 6x6 if i can buy a horse lol help
