Hustler t20 clutch question
  • Hustler t20 clutch question
    Can anyone tell me the t20 clutch size for a hustler 980? Mine is bad and i want to just replace it but i want to make sure i get the right bore size.
    The bore for a T20 clutch is 7/8", but if I remember right, the outside diameter of the Hustler clutch is smaller than most of the ones we use. that's easy enough to measure on the machine.
      Do you know where i could purchase the clutch for a hustler? I did find this one i assume this would work but i http://www.mfgsupply.com/300782a.html what do you guys think
        Check ebay...they were on there for about half that much. You just never know what spring they will have, but a red spring from R.I. is only $25.
          Thanks buggyman
            Quality Drive Systems
            Try this fellow his is probably one of the most knowledgeable fellows on this type clutch. His name is Roy. Great fellow. Tell him the size.
              Hi..forgive my question but what is a red spring?
              Thanks
              Chris
              (BigMaxII with JLO 440)
                Never mind...I just "red" another post answering my question about the Red spring..
                Chris
