Can anyone tell me the t20 clutch size for a hustler 980? Mine is bad and i want to just replace it but i want to make sure i get the right bore size.
Hustler t20 clutch question
The bore for a T20 clutch is 7/8", but if I remember right, the outside diameter of the Hustler clutch is smaller than most of the ones we use. that's easy enough to measure on the machine.Stuck in the seventies- not in the swamp.
Do you know where i could purchase the clutch for a hustler? I did find this one i assume this would work but i http://www.mfgsupply.com/300782a.html what do you guys think
Quality Drive Systems
Try this fellow his is probably one of the most knowledgeable fellows on this type clutch. His name is Roy. Great fellow. Tell him the size.Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
