Hey all you MaxIV owners, here the next thing you should never do or you should make sure you do with a Max. When you change your wheel bearings and take your axles out make sure when you reinstall your axles that that retaining bolt that holds the axle on (it secures the axle to the smaller inside bearing) make sure this bolt is tight!!!!! Why do I say this? I didn't tighten the right rear retaining bolt as tight as I should have, as a result the bolt got loose and the axle started to walk out, meaning the chains got out off alignment and walked the chain on the right rear side off the T-20 and the sprocket. For those of you who own a MaxIV you know that getting that chain back on a MaxIV requires just a little more then a bit of effort.
So learn from my mistake and insure those bolts are secured against that axle!
