I've owned my 94(?) MaxIV for a few months. I'm still learning about it and small engines in general.
My MaxIV was running well, until yesterday when it started to make light 'clinking' noises back towards the engine. It did this intermittently for several minutes and i thought maybe it was just ice breaking off under the wheel-well. Then it made a rumbling noise and then a screech/groan. The engine died.
I tried to key-start the engine, but the starter only made a "whirring" sound, with accompanying clinking noise. It almost sounded like the teeth were stripped off the starter engine gear, or the gear has shattered and the plastic parts were bouncing around inside.
So I used the pull-rope to start the engine again. Started great with 1 pull. While out-of-gear, I revved it to full RPMs and everything sounded fine. However, when I put it in forward gear, and slowly revved, I moved a few feet then heard the groan and screech again, and the engine died.
So, any ideas? Is there anything that could happen in the drive-train or transmission or axles (seized/broken bearings?) that could damage the starter engine? I'm still reading up on how to remove the starter engine to check it. (I'll tackle that this weekend.) I don't even know where to begin on the larger groan/screech that I'm hearing while rolling forward in gear.
