Max II Throttle Lever
  • Max II Throttle Lever
    Well mines about broke. Anyone ever use a Snowmobile Throttle block & lever ? I see lots of people using bike levers. If so any recommendations. I like the snowmobile level because thay can be found made of metal.
    Recreatives sells an aluminium replacment thats a direct replacment for the plastic one....
    "You've got to stand for something, or you'll fall for anything"
    "Theres the right way to do things, the wrong way to things, and the way everyone else does it"
    Max II, 22 Inch Rawhides, Winch, 16hp Briggs Vanguard...My First AATV...
      One Question. Why do thay not use a "normal" gastrottle like thay use it on a motocycle?
      kind regards
      Frank
        kind regards
        Frank
        I dont know
          Frank,
          I think one reason is that with a standard twist grip throttle, If you mount it on the lateral stick it turns the wrong dirrection. You would need a reverse mechanism one to have it feel correct, and i haven't found one yet.
          But the handles have been modified before to make it work.
          MAX IV Mark
          OOO-(
          Never argue with an idiot, they will drag you down to their level, then beat you to death with stupidity!
            Hallo Mark.
            Thank you for this picture. I will build two joysticks like yours. For me it`s better, to have the two handles in horizontal Direction. I like to drive motorcycle. So it is for me more comfortible
              kind regards
              Frank
              The Swamp Fox, Argo, and possibly a few other AATV used the twist type throttle like on a motorcycle.
                A metal lever from a kids bike works great and is more durable, you may have to drill it a bit for the cable to fit but it easier than modifying the sticks and works nice I think I have pics on here of mine
                  i used an old ski doo metal lever
