Well mines about broke. Anyone ever use a Snowmobile Throttle block & lever ? I see lots of people using bike levers. If so any recommendations. I like the snowmobile level because thay can be found made of metal.
Max II Throttle Lever
Recreatives sells an aluminium replacment thats a direct replacment for the plastic one...."You've got to stand for something, or you'll fall for anything"
"Theres the right way to do things, the wrong way to things, and the way everyone else does it"
Max II, 22 Inch Rawhides, Winch, 16hp Briggs Vanguard...My First AATV...
I dont knowOriginally posted by Bavaria View PostOne Question. Why do thay not use a "normal" gastrottle like thay use it on a motocycle?
kind regards
Frank
Frank,
I think one reason is that with a standard twist grip throttle, If you mount it on the lateral stick it turns the wrong dirrection. You would need a reverse mechanism one to have it feel correct, and i haven't found one yet.
But the handles have been modified before to make it work.
MAX IV Mark-----
OOO-(
Never argue with an idiot, they will drag you down to their level, then beat you to death with stupidity!
The Swamp Fox, Argo, and possibly a few other AATV used the twist type throttle like on a motorcycle.Originally posted by Bavaria View PostOne Question. Why do thay not use a "normal" gastrottle like thay use it on a motocycle?
kind regards
Frank"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
