How much play roughly in inches is ok on the chains? Mine still looks ok but i just wanna make sure they dont start running loose...also...is there a good hour interval for tensioning them?
Chain Tension....
Chain Tension....
"You've got to stand for something, or you'll fall for anything"
"Theres the right way to do things, the wrong way to things, and the way everyone else does it"
Max II, 22 Inch Rawhides, Winch, 16hp Briggs Vanguard...My First AATV...Tags: None
Dustin, I just tightened them before you got it.
To answer your questions, is a little more difficult. Tension: Tight, but not too tight. You don't want a lot of slop, but also don't want them to be banjo tight. If you had 1/4" to 1/2" movement mid chain with moderate pressure, you are about right.
Tension interval: Check them regularly, I'd suggest when you grease the bearings...at least every 10 hours of use......That hour meter is your friend.
Yeah...im a lil parnoid about stuff on it....it is a rock solid machine and i wanna keep it that way
So yes ill be asking tons and tons and tons of questions because i dont wanna end up taking a nice machine and it being a POS in the end because of my negligance
Thanks jim."You've got to stand for something, or you'll fall for anything"
