I am highly considering fabricating/installing a truck-like bed over the rear of my Max 2. My question is, has anyone ever done this before? I live on a large piece of property and wanting to put my amphib to work! I have attached photos of the type of bed I'm considering.
Utility Bed for Max 2?
I have seen it done before. My suggestion would be making a mount with a quick release that could attach to a belly band bar on either side of the engine compartment. Really the mount would be not much more than a couple pieces of flat steel top and bottom of the belly band. The top one would have 2 pieces of square stock (front and back) with a hole drilled in each piece for a pin. The rack would need to have smaller pieces of square tube that fit inside the bottom mount with a hole drilled for the pin. I am pretty sure this is the most common method of making a rear rack.l like to buy stuff and no I don't do payments!
http://item.mobileweb.ebay.com/viewi...id=21524724715 this is the rack I've had on both my max II's and I love it. I also include a black milk crate for smaller items.
That looks like it might work! Plus a whole lot cheaper than what I was thinking on spending. Do you have any pictures with it installed?Originally posted by 814cannob View Posthttp://item.mobileweb.ebay.com/viewi...id=21524724715 this is the rack I've had on both my max II's and I love it. I also include a black milk crate for smaller items.
Do you have to remove it to lift the top tub?
sorry the photos are not the best. think i used 3" or 3-1/2" S.S. bolts. and onlt used (3) of them.
