hey guys iam a new member from Hamlin wv, close to the capital. I now own my dads maxx 2 that he has had new since 1998. I have adjusted all the chains, they weren't to bad to begin with. The only chain iam having problems with is the rear chain running beside the motor, and clutch. I have the bottom adjuster up enough to get the bottom of the chain pretty snug, but the problem is that all the slack is in the top, I can pull the chain up to the top of the frame rail. Any ideas? I also read about the get to gather at hatfield McCoy trail, prob gonna try and make it to that thx
maxx II owner from hamlin wv
Welcome to the site. If you will raise the machine off the ground so that the tires can move freely, the slack can be taken up. That's the easy way. You can also just take your hands and spin the tires while the machine is on the ground. Grip the middle tire with both hands and spin it forward. Then spin the rear tire in reverse and the slack will now be at the bottom.
Something just doesn't sound right. Did you have the transmission in neutral while you were trying to rotate the tires opposite directions? Also, maybe you do have the chain tight enough? You don't want them real tight, ideally you want an 1/8" movement up and 1/8" movement down as well. Since the chain tensioner is on the bottom, there will be some slack on the top. The Max II chain adjusters ratchet so there isn't much fine tuning available. Sometimes you have to leave them a little loose until they wear a little more. Then you can tighten to the next position. When you do that, the chain is usually too tight for a little while until it wears some more. Rinse and repeat.
Just throwing some things out there.
That is correct, you were doing that the right way. Measure how much slack you have with a tape measure so that we can tell just how bad it is. Put the tape measure in one location then push the top of the chain down. Take a reading on where the top of the chain is pushed to. Then pull it up and take another reading. Take the difference and post that so we can tell just how much slack you have.
