Can the bearings be replaced in the chain adjuster sprockets? It looks like that they are just pressed in. I hate to replace the whole sprocket when just the bearing is bad. If any of you guys have replaced them could you give me part numbers. 2000 Max IV.
chain adjuster sprocket bearing replacement????
Here are a couple of sources I use.
Big Bearing out of Tennessee have always been helpful and fast.
17 Tooth Steel Idler Sprocket for #50 Roller Chain
G&G MFG out of Omaha have also been outstanding, and G&G does most of RI's manufacturing needs.
Idler SprocketsThe trouble with retirement is.... I never get a day off !!!!
