I found pieces of the outer bearing inside the tub that got me started on this... This Buffalo has the splined axle's with the two set screws in the locking collar. I blew off all the crud and cleaned it up, took both set screws out, soaked everything in WD-40 and applied a little heat to the locking collar and I still can't seem to get the axle out. It should slide out at this point, right? Do I need to remove the inner bearing flange? Am I missing something? Here are some pics of my progress...
