1/2 way there?
Carbide tipped masonry bits were the way to go. The tip of the hex wrench was made of S2 tool steel and made it nearly impossible to drill with the cobalts. The cobalt bits were only useful after I started a pilot hole with the masonry bit. After that, I alternated between the two and some left handed drill bits. So after spending about 6 hours in the garage, I managed to get the tip of the set screw out. You'll notice that I wasn't able to drill straight through and ended up drilling off at an angle and into the axle. I would have stopped sooner, but I didn't notice I had drilled out the set screw from the previous night...I found it laying in the tub this morning. From the top of the sprocket to the bottom of the hole I drilled measure about 2 inches.
So now that it's out, I still can't slide out the axle. I slam away with a slide hammer every time I put the drill down, but it just won't budge.
Any ideas? Is the axle still worth saving assuming I probably drilled a 1/4 deep hole in it?
-2 HOURS LATER...
I though I was home free with this idea...Tried pushing the sprocket off with a bottle jack sitting on the back end of the hub. I got a good bite and the bottle jack is not slipping, but it seems like I reached the capacity of the jack. Sprocket not budging. I may run out and get a 20 ton jack. If that doesn't work I think it's time to cut.
-2 HOURS LATER...
