ok climbing a big hill to day the max stoped pulling and smoked the belt. what is the cause of it .???????
belt slipping
belt slipping
1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
R.I.P sage rogers 4 11 09 .
Tags: None
I was running an older belt on my tt. It was worn out and would do that on hills when needed torque. It was worn so the lower ratios of the cvt werent being used because it sits lower in the driven pulley and makes it higher in the drive so its like taking off in 2nd gear type situation. That could be a possibility.
Originally posted by micmac View PostWas it your new Max or older one?1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
Originally posted by jerrynuss View PostHad you been in the water or was there water in the tub?1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
must have been wet . we road it tonight and it worked right had a ball. had to use the winch . robbie
Originally posted by jerrynuss View PostThe IV is a little more affected by water in the tub causing the belt to slip.Last edited by rdr; 04-06-2008, 09:40 PM.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
Belt dressing will help the life of the belt but if it is wet it won't matter. I just let it slip and let the heat and and motion remove the water. It should be set ok from the factory and your belt is way to new to worry about adjusting or replacing.
Just drive it and if you are going to be in the water often put a bilge pump in.
