working on my max IV
  • #16
    Awesome work. What size diamond plate did you use on the floorboard? Did you add any extra support underneath to help?
    • #17
      1/8" I put 1"x 1" square tube across the frame with ears welded to them then bolted it to frame so I could remove them if needed then use self tappers to attach the plate make sure you leave a cut out up front for the gear selector lever( F&R )
      THANKS for checking it out
      • #18
        I also bent a 10" lip on the back so the engine compartment would kinda be closed off
