hi all living in florida my toys are always in the water.is anyone out there running stainless steel bearing inserts in there machines. Iam rebuilding my max now with new sprockets and shafts supplied by whipper, im trying to make the best upgrades I can thanks. mark
max iv stainless bearings
I would look into plastic bearings. Tim at Adair Argo has a design that looks good. I use plastic in trailers we tow in the swamps. No more bearing failures. The salt water gets into the ball bearings that are hardened steel and erode the finish. Stainless bearings would probably have hardened steel balls?? Hope you find something that lasts.
Those work very well. 6X6World member Micmac did that on his Max IV.Originally posted by jerseybigfoot View PostIf you have the older small outer bearings you can use Argo outer seals to protect the bearings
Marc, do you know offhand what year Recreatives switched from 62mm bearings to 72mm on the IV?"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
