Mmy max IV is older, had roll bar on it. has the big tires, and the black tub is about half a mm from rubbing. anyone know of any ways to remedy this? I thought about adding two tubes from the frame to the top of the roll bar, hoisting the roll bar up, then welding it in so there is tension and will raise the body some.
Sides Sagging
Do you generally carry alot of weight, something is causing the body to sag.
I think part of the solution will have to be to fix that first, other wise it may just pull the roll bar lose.
But I agree twenty thousands(.02) is very close to the tires.
Bruce
I took my seat belts off and also the plates that bolt them onto the inside of the tub , and later found out that my tub was sagging .
I then reinstalled the factory seat belt plate , but this time minus the seat belts , and this ended my sagging tub problem .
sagging
One of the things that will cause a max to sage is tying down the machine and transporting the machine by strapping down the roll bar. The owners manual warns against this and recommends that the max be transported or secured by strapping the axles and to never transport or store the machine with straps holding down the roll bar. They warn that this will cause the body to sage. Also direct sunlight could cause a sage if stored in the open over a long period of time. You can gain clearance by deflating the tires and placing a board or brick between the tire and the body. Heat the body (being very carefull here not to melt it) and then air the tires up to gain the clearance you want. When the body cools take out the board or brick and the body will hold the heated shape with added clearance. Be carfull here! Easy does it! Hope this helpsLast edited by mightymaxIV; 04-13-2008, 09:52 PM.
Interesting facts mightymaxiv.Originally posted by mightymaxIV View PostOne of the things that will cause a max to sage is tying down the machine and transporting the machine by strapping down the roll bar. The owners manual warns against this and recommends that the max be transported or secured by strapping the axles and to never transport or store the machine with straps holding down the roll bar. They warn that this will cause the body to sage. Also direct sunlight could cause a sage if stored in the open over a long period of time. You can gain clearance by deflating the tires and placing a board or brick between the tire and the body. Heat the body (being very carefull here not to melt it) and then air the tires up to gain the clearance you want. When the body cools take out the board or brick and the body will hold the heated shape with added clearance. Be carfull here! Easy does it! Hope this helps
I wonder if in storage, if it were to hang by the rollbar if it would help, lol.
Body sag --Max iv
Mighty Max has the fix and probably the cause but in hot weather my max iv got close to the 26 Terra grips because I have a homemade cage and no seatbelt kit. I made up a bar that goes across behind the rear seat and fastens to the seat and the lower tub. Jack the machine up by the tub till you can hook up the bar, do the other side and your done. Instead of making up my own bar I could have gotten the right one from RI.Originally posted by mudbug3 View PostI took my seat belts off and also the plates that bolt them onto the inside of the tub , and later found out that my tub was sagging .
Body sag --Max iv
Lets see if Mudbug can post a pic of the factory setup. Its simple and right. If not I can get you a pic of what I did. Same idea that you had with the posts coming up from the frame.The rear seat does come up from the frame. If a bar(1" square) runs across from side to side over top of the metal that holds the seat pad and bolts to the tub, you're done. I jack the max up.put a 2x4 under the tub and lower the max till the tub comes up the bar and I can nut it up. Mudbugs plate is more attractive and has slots so you can mount seatbelts, I should have got that from RI.Originally posted by mrarmyant View PostHave any photos? I'm confused.
Sagging Body
Hi everyone... I got this problem on my 1985 Argo Vanguard and i got a good solution if it can be install on a Max too... It simple, newer Argo has a frame under the seat, this frame hold both sides of the body, preventing sagging and tire rubbing... I can't post pictures because they are too big but send me a private message and i will send it to you by email. That way you will understand how it goes... Hope it could help you...
Martin
